Replacing Battery
Old 2nd Dec 2006, 4:52 pm
cv1 cv1 is offline
Default Replacing Battery
Hi i just bought a 400mAH battery and i need help can someone let me know the process of how to remove and replacing the battery on my nano clone.
Old 2nd Dec 2006, 5:38 pm
Default Re: Replacing Battery
cv1 , there is a post by graylinghunter Here, on his battery modification to an ipod nano battery. You might want to read it up first. Most importantly, measure the maximum available space with your replacement battery to ensure a fit.
Generally, you will need a soldering iron, solder wire, insulating duct tape & a fair degree of soldering skills.
Just tape up the White wire, make sure no wire from the White one is left exposed.
Next remove the old battery, and apply abit of solder to the 2 solder points on the board. Remember which of the 2 points are for the red and black wires.
Now solder the red and black wires to the original points and thats it.
Old 2nd Dec 2006, 9:47 pm
cv1 cv1 is offline
Thanks!! It worked
Old 21st Dec 2006, 12:21 pm
HI, This 400 MaH battery you installed, how is it now?? I assume the higher MaH gives longer usage time than the MP4 factory ones?? Just curious. I have noticed on ebay and Uxcell that they have replacement batteries for Ipod Nano's are these ok to use as a replacement for the MP4 players??
Cheers
Joffa
Old 22nd Dec 2006, 5:15 pm
N3o N3o is offline
cv1 tell us more about the battery that u purchased, and how are the results?
Replacing to all new firmware kingmax General Discussion 1 25th May 2009 3:59 pm
Opening and replacing battery Dr.Fix Support and How To 5 12th Oct 2008 1:01 pm
Need help replacing battery... DeltaFX Support and How To 7 30th Nov 2007 8:36 am
Replacing the battery in my Full Metal Platinum (2gen Nano) michiganjfrog Support and How To 9 7th Mar 2007 9:12 am
Broken screen, needs replacing myschyf Support and How To 4 22nd Nov 2006 6:34 pm
