Sound not coming out properly
Old 5th Dec 2006, 12:43 am
Default Sound not coming out properly
Hi
Somethings wrong with my player as when i play any music with headphones pluged in the music only comes out in one ear which is really bugging me.
Any help would be xclnt.
Old 5th Dec 2006, 1:29 am
Dulithak, Have you tried a different set of earphones the ones you are usiong may be faulty. Generally the ones that come with the player are poor quality and you should invest in better quality pair.
Failing that there may be a faulty connection in the socket.
Old 5th Dec 2006, 1:42 am
Que Que is offline
Pushed them in far enough? If other headphones don't work too, open up the player and check the connector's soldering. Someone here had that too, and found 1 of the joints was not soldered at all.
New mp4 not compatible/ no working properly kaseyh87 Support and How To 2 6th Oct 2009 6:56 pm
mp3 generic player doesn't work properly pseudolongino Dead Players 1 26th Feb 2008 9:36 pm
Howto: Properly recharging your MPx player Th3_uN1Qu3 Support and How To 2 24th Jul 2007 3:30 am
won't charge properly Podder Support and How To 3 1st Mar 2007 6:59 am
MP4 Player not working properly Marekso Support and How To 4 21st Nov 2006 10:17 am
