Problem with volume on 1GB player.
Old 6th Dec 2006, 2:52 pm
Default Problem with volume on 1GB player.
Hi,
I get a very soft volume in some AMV files i created and some of my MP3s are too loud and some are too soft. Is there any way of setting the volume to be the same in all 900 of my MP3 files and all 40 of my AMV files ? Some sort of batch process or other workaround ?
Old 22nd Dec 2006, 5:15 pm
Default Re: Problem with volume on 1GB player.
i am also looking for a way to boost the sound volume. Have you found a way?
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Old 22nd Dec 2006, 9:05 pm
jp jp is offline
When I watch videos I prefer to use my players built in speakers rather than headphones and have to boost the volume accordingly. I do the volume adjustment and conversion as follows:
1. Convert VOB files to mpeg 1 using SUPER converter selecting the ffmpeg choice...video options / other options allows increasing volume 300% which I do...
2. Convert mpeg 1 to avi using Virtual Dub to edit video characteristics including brightness, contrast, sharpness, cropping, frame rates, cut into small segments for easy mid video resumption, remove unwanted video such as pre and post segments such as credits, etc.,...can further adjust volume here as well if necessary which I sometimes do...
3. Convert from avi to amv ... I use version 4.00 as my player supports 16 fps and the 128 by 128 option crops the frame edges so no compression of the frame itself...find that the little bit cropped doesn't affect viewability...
There is a limit to how much volume can be increased before the sound degrades. You may want to convert the same short piece of video using various settings to see what sounds best. Save each so you can play them one after the other to compare.
I've played around with various approaches but in terms of volume increase, using SUPER then VDub works better than VDub alone plus must convert VOB files before using VDub anyhow. Somewhat labour intensive though and perhaps a non-freeware program may allow more batch conversion options. However I find that to optimize picture quality this approach is necessary as there is variability in the brightness and clarity of different movies or tv shows, so adjusting the volume as well takes no more time.
In doing format conversions from mp3 to wma using Media Monkey, I've noticed a track volume leveling option that may solve your mp3 volume issues. I haven't played with it so am not sure how effective it is.
Also, I record radio broadcasts that I access via the web, usually sports shows, and record them using Free Hi-Q Recorder which allows recording volume adjustment. Again, I listen to these using my players built in speakers so find that recording volume adjustment necessary.
Old 22nd Dec 2006, 9:07 pm
MPx-a-lolics Anonymous
as far as your mp3 songs are concerned maybe you could try normalizing the tracks before uploading them to your mp4 player.
as far as amvs are concerned you could perhaps try the following -
1. Follow Tadad's AMV Guide
2. Add a step in which first you make sure that Audio (in the topmost bar) is set to full processing mode.
3. Choose Volume from Audio and increase it to around 300% while making sure that the Adjust Volume Channels box is ticked
Hope this helps
Volume down = volume up? Opirian Support and How To 1 3rd Jan 2008 9:06 am
Hiss and low volume. mallen Support and How To 5 13th Mar 2007 9:21 am
AMV Volume issues mmginc Video related 5 23rd Feb 2007 11:38 pm
volume??! jaidagr8st Support and How To 1 26th Jan 2007 2:57 am
MP4 Player Volume? Scooper Support and How To 7 4th Jul 2006 3:20 am
