Memory problem, no radio ????
Old 19th Dec 2006, 8:36 am
jellalit's Avatar
ok thanks lattesurf and tadad1,
Old 19th Dec 2006, 9:00 pm
I bought a new 1GB MP3 player (China make). In the players memory info, it shows 1Gb, but it was unable to load 1Gb of songs. Pl help me how to use total memory.
Old 19th Dec 2006, 9:09 pm
sree, If you have MP3 layer Utilities installed connect your player and run the MP3 Player Disk tool.
Have a look at the capacity on the format tab and the capacity on the Partition Encrypt tab, do the match or are they differrent?
http://www.mympxplayer.org/feedback-...rs-vt2828.html
4GB iTouch copy with memory problem - full memory dobo_d1 Support and How To 3 2nd Jun 2008 8:02 am
radio problem jithendra Support and How To 6 28th Mar 2007 8:09 am
Problem with Radio / Record. azraelpc Support and How To 5 22nd Jan 2007 2:02 am
Radio problem gkatsogr Support and How To 7 29th Sep 2006 3:35 am
FM radio problem flik Support and How To 2 2nd Sep 2006 4:47 am
