Memory problem, no radio ????
Old 19th Dec 2006, 3:46 am
jellalit's Avatar
Default Memory problem, no radio ????
HI,
I have by a sony MP4 digital player, but my problem is:
my mp4 player supports 256 Mb dispite he accepts 107 Mb only, if I copy filesmore than that the files don't work they are corrupted my mp4 player dosen't play them and my os too.
My second problem is :
I d'ont have radio in my mp4 player the option radio is not here ???
please help me
thanks...
Old 19th Dec 2006, 4:34 am
jellalit, It sounds like you may have a hacked player. Your chips true size may only be 128MB but it has been hacked to read as 256MB. With these chips when you add files above the chips true size the files become corrupted and will not play.
You can check like it with the MP3 Player Disk Tool which is part of MP3 Player Utilities.
http://www.mympxplayer.org/feedback-...rs-vt2828.html
To fix the corruption you need to remove the hack from the memory chip like this.
Regarding the radio function not all players have the radio chip installed.
Old 19th Dec 2006, 5:17 am
jellalit's Avatar
tadad1, thanks i will chek that.
and the radio i c'ant istall it ?
Old 19th Dec 2006, 5:40 am
jellalit, There is no way to add the radio feature to the firmware and your players mainboard may not have a radiochip.
Old 19th Dec 2006, 5:59 am
jellalit's Avatar
ok, that's not my very big problem my problem is the memory,
can you find a direct link to download mp3 player utilites tools. rapid share dosn't work for me...
Old 19th Dec 2006, 6:17 am
here is a link for 4.07
http://uploaded.to/?id=2befe6
Old 19th Dec 2006, 7:25 am
jellalit's Avatar
finish, but i have in th front of my mp4 player 256 Mb and now i have 108 mb only no solution ??
what's a hacked player ?
Old 19th Dec 2006, 7:34 am
jellalit's Avatar
Old 19th Dec 2006, 7:41 am
jellalit's Avatar
Old 19th Dec 2006, 8:00 am
Default Re: Memory problem, no radio ????
jellalit , the term "hacked" in the memory capacity context is where the memory chip is re-programmed to tell the operating system of a much larger capacity then it is supposed to be.
Your player had been hacked by the manufacturers to make it look like 256MB when it is actually just a 128MB chip. There is nothing you can do to "recover" the lost 128MB.
What you can do is either live with the 128Mb player, or to contact your seller and either get a full refund or partial refund.
4GB iTouch copy with memory problem - full memory dobo_d1 Support and How To 3 2nd Jun 2008 8:02 am
radio problem jithendra Support and How To 6 28th Mar 2007 8:09 am
Problem with Radio / Record. azraelpc Support and How To 5 22nd Jan 2007 2:02 am
Radio problem gkatsogr Support and How To 7 29th Sep 2006 3:35 am
FM radio problem flik Support and How To 2 2nd Sep 2006 4:47 am
