How Formatear MP4
Old 19th Dec 2006, 11:17 am
Default How Formatear MP4
Hi, is my again xD
My MP4 is that:
http://hk.geocities.com/bestmp4kennethwong/mp4_1.jpg
But, i need to "formatear" (clear of all) my MP4
Existing any soft, for doing that?
(Sorry for my bad english xD)
Old 19th Dec 2006, 4:00 pm
Que Que is offline
If you connect it, is it detected as an extra drive? If so, you can format it by rightclicking, and choosing "format". See first if it has specific folders for record or video etcetera, make them again after the format.
Old 19th Dec 2006, 5:27 pm
Default Re: How Formatear MP4
But, i need format the soft. Because:
http://www.mympxplayer.org/here-df441.html
Bye & Thank you, for helpme ^^
Old 19th Dec 2006, 5:40 pm
Stranyer, There are no tools to remove/format/delete the firmware from your player. I gathr from your post that you have tried to upgrade your firmware with the 9.0.48 version you downloaded. What version was your original firmware and what is happening with your player at the moment?
