Card Error - HELP!!
Old 10th Jan 2007, 5:42 pm
Default Re: Card Error - HELP!!
My Rockchip has problems writing a lot of files to miniSD cards. I bought some 1GB 80x cards and if I try to write heaps of files, it crashes and disconnects from the PC. I rushed out and bought a card reader and it works fine!
Friendly Beatings Available - Enquire Within
Old 11th Jan 2007, 9:53 am
Originally Posted by xithrix";p=&quot View Post
i hav a MP4 that its something like this
http://www.mympxplayer.org/image-full-asp204.html
http://www.mympxplayer.org/album_sho...php?pic_id=172
with this software -> http://www.mympxplayer.org/album_sho...php?pic_id=126
and with sd/mmc card adaptor... i plugged in my 512mb MMC card from my nokia 6230 and it worked just perfect... then i ordered a 2gb SD card from Mercado livre (a brazilian ebay) and when i plug him in he always give me "Card Error" and some chinese letters... the card is working perfectly... why could it be not working...?
ill post some pictures of the actual player later on...
PLZ HELP!! the 2gb sd here isnt that cheap =X
Try Formatting in FAT no FAT32
Mp3 player with sd card ikepro Support and How To 4 3rd Jan 2009 6:18 am
[solved] File Format Error for MP3s & Videos on SD-Card anchelito Support and How To 5 28th Sep 2008 12:21 am
[solved] Dead SD Card - card unreadable UzY3L Miscellaneous 2 19th Sep 2008 1:39 pm
Putting video onto SD card, shows card error jignesh_1000 Support and How To 2 28th Aug 2007 7:51 pm
card error man88e Support and How To 3 22nd Aug 2007 10:38 pm
