Card Error - HELP!!
Old 22nd Dec 2006, 11:13 am
Default Card Error - HELP!!
i hav a MP4 that its something like this
http://www.mympxplayer.org/image-full-asp204.html
http://www.mympxplayer.org/album_sho...php?pic_id=172
with this software -> http://www.mympxplayer.org/album_sho...php?pic_id=126
and with sd/mmc card adaptor... i plugged in my 512mb MMC card from my nokia 6230 and it worked just perfect... then i ordered a 2gb SD card from Mercado livre (a brazilian ebay) and when i plug him in he always give me "Card Error" and some chinese letters... the card is working perfectly... why could it be not working...?
ill post some pictures of the actual player later on...
PLZ HELP!! the 2gb sd here isnt that cheap =X
Old 22nd Dec 2006, 12:01 pm
Default Re: Card Error - HELP!!
some players state they only support 1Gig cards, have no idea why though. where you get it from?
Old 22nd Dec 2006, 9:29 pm
xithrix , as what broose had mentioned, your player might only support 1GB of SD memory, hence the error.
Also try formatting the SD memory to fat16.
Old 23rd Dec 2006, 5:43 pm
i don't hav a SD card reader right now ill test the fat16 later otherwise ill trade it with a 1gb =/
anyhow... heres some pics of him... behind the sticks is written BakJapan
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
thx alot
[]'s
edit:
_______________________________
one more thing... can u guys tell where/if i can get the firmware update for this one... i read somewhere (here i think) that u need to open to know wich firmware to get... but im kinda scare to open him... =X
Old 23rd Dec 2006, 5:53 pm
xithrix, I would not try updating the firmware as it will most likely kill your player and recovery may be impossible.
Old 28th Dec 2006, 10:17 pm
I ai cara blz ?.. ou eu tenho o mesmo mp4 que o seu, mais o meu é vermelho naum é laranja o detalhe... cara eu comprei ele principalmente pq tinha entrada pra cartao... putz ainda naum tentei colocar um cartao nele to juntando dinheiro pra comprar um cartao de 2gb... no meu parece que da pra colocar ate de 4 gb... vei vou ate ohar aki... vc fez alguma atualização de firmware ? Coloca uma foto da caixa dele atras e na frente pra eu ver se o seu é o mesmo que eu poço tentar te ajudar...
Old 3rd Jan 2007, 5:56 pm
eu fiz nenhuma atualizacao naum to com medo d faze...
eu posto a foto da caixa amanha c meu irmaum dexa eu usa o pc q essa hora num to com a camera aki...
onde q vc comprou o seu? o meu comprei em camboriu... 270 conto... axei moh pexinxa.. a mema coisa no ml soh q com tela d 1.8" tava 260 Oo
Edit:
_______________________________________________
xD nem reparei q parece laranja ali nas fotos... eh q tirei d noite entum tive q tira com flash mas eh vermelho tb sim...
v c ai na tua cidade tem algum lugar q eles t deixem testar o cartao na hora... eu axo q o mmc chega ate 1 gb e funca...
Old 4th Jan 2007, 1:16 pm
tai a caixa pra tu tira a duvida
Old 10th Jan 2007, 5:30 am
i just got an SD card reader and formatted to FAT32 and FAT through windows and got the same card error as always :/
Old 10th Jan 2007, 6:04 am
just one more thing... first after i put the card it gives "Card error!" and some chinese letters on the background
then it shows no JPG files (cuz there aren't any in the mp4 internal memory)
and finaly it shows CARD EMPTY!!
just thought this could help somehow...
Mp3 player with sd card ikepro Support and How To 4 3rd Jan 2009 6:18 am
[solved] File Format Error for MP3s & Videos on SD-Card anchelito Support and How To 5 28th Sep 2008 12:21 am
[solved] Dead SD Card - card unreadable UzY3L Miscellaneous 2 19th Sep 2008 1:39 pm
Putting video onto SD card, shows card error jignesh_1000 Support and How To 2 28th Aug 2007 7:51 pm
card error man88e Support and How To 3 22nd Aug 2007 10:38 pm
