IPod Clone not charging - Now battery is dead!
Old 26th Dec 2006, 5:45 am
Default IPod Clone not charging - Now battery is dead!
Hi,
I bought this IPod Clone on EBay for my Son as part of his Christmas Present but it does not seem to charge? It charged up initially (yesterday morning) and I also put a few mp3 on it for my son and it played for a few hours but now it does not charge and it does not get recognized when I connect the USB into the computer? What can be wrong? I was thinking it might be something to do with the USB cable (since it does not get recognized as a drive in my computer)? I have tried it on 2 different computers and it does not charge with the plug either. For a while, it was switching on (but shutdown after a few seconds with a low battery) but now I think the battery is completely dead as it does not switch on anymore. Have you seen this problem before? If so what is the solution. If not what can I do?
Jerome
Old 26th Dec 2006, 6:53 am
jeromeof , ensure the on/off switch on the top is set to the on position.
Try plugging in your player to the computer and leave it "charging" for a few minutes and see if there are any signs of life.
Also, are you using a USB hub? If you are, disconnect the USB hub and connect the player directly to the computer's USB port.
If all these fails, likely your battery might be totally dead. i'll suggest you contact your seller for an exchange or refund.
MP4 8GB ipod clone battery acting strange yessirsir Support and How To 0 21st Feb 2009 10:41 pm
how can i change battery from a ipod clone? Ecege Support and How To 0 6th Jul 2007 6:16 pm
iPod Nano Clone Battery Life aurelio General Discussion 5 30th Mar 2007 5:34 pm
Charging ipod nano clone pinas Support and How To 14 26th Oct 2006 10:47 am
Nano Clone ipod 1GB -- battery change jasstone General Discussion 3 13th Jul 2006 5:53 am
