formatting Problems
Old 28th Dec 2006, 8:16 pm
Default formatting Problems
Hay everyone i have a version LSD_9101_20 version 9.0.48 with a lcd screen and i had a problem with the disk and had to format and it only let me format to 1GB when i first bought the player it was 2GB drive any suggestion on how to find my other 1GB
Old 28th Dec 2006, 8:22 pm
MPx-a-lolics Anonymous
its good that your formatted your player.
your player was hacked to show the memory as 2 gb although your player's memory was actually only 1 gb.
Old 28th Dec 2006, 8:30 pm
Default Re: formatting Problems
It was hacked?? even if the mp3 player was store bought??
Old 28th Dec 2006, 9:03 pm
shawn_13 , many sellers (both online and stores) get their supplies from the same few distributors and manufacturers. So the likelyhood that they are hacked are also there.
i'll suggest you go back to the store for a refund.
Formatting SuePaterson Dead Players 13 24th Jan 2007 4:49 pm
Formatting the Player Jesus_Saves Support and How To 5 31st Jul 2006 9:51 pm
2Gb now 1GB after formatting cbbreogan Support and How To 2 8th Jun 2006 10:14 pm
Formatting MP4 SWISH Support and How To 1 5th Jun 2006 3:52 am
formatting david_marshall Support and How To 5 19th May 2006 2:38 am
