Telbook Problem
Old 31st Dec 2006, 7:57 am
Default Telbook Problem
Hey - I have Firmware 9.0.43, I looked at the Driver CD and it had a Telbook application and a .bin file.
Does this mean I can add Telbook to my MP4
It isnt listed though ;S But.. whys the files included?
Please Help - Thanks!
Old 31st Dec 2006, 10:36 am
Dean786 , these players usually come with cds which are mass manufactured for many types of players.
Most of the programs are common (eg mp3 utilities), whilst others are only particular to certain players only.
Your player should support the telbook feature, but i'll not recommend doing anything to the firmware as you would have noticed already that the 9.0.xx series are giving alot of firmware problems.
The .bin file might be the player's firmware file, but only use it if you are recovering a dead player.
TelBook Instructions (VL-547) Vinh Support and How To 24 22nd Feb 2008 2:24 am
plz help with telbook giroblade23 Support and How To 3 5th Jul 2007 1:11 pm
How can you create a TelBook? caLVin Support and How To 3 5th Jan 2007 5:00 am
mp3345 without telbook junak General Discussion 8 4th Oct 2006 11:09 am
download telbook links dead Alejomar General Discussion 3 18th Sep 2006 7:50 am
