De-Hacking Method would not work
Old 1st Jan 2007, 7:00 pm
Default De-Hacking Method would not work
Hey, ui tried the de-hacking method but I cannot slide the slider at all. Also,. the CD would not work when I have bought the player. Please help.
Old 1st Jan 2007, 10:27 pm
MPx-a-lolics Anonymous
thats strange.
try downloading MP3 Player Utilities 3.57
it has everything you need from disk tool, firware upgrade to amv converter
Old 3rd Jan 2007, 4:46 pm
The download doesnt' work. Got another link?
弱々しいカルヴァン
Old 3rd Jan 2007, 10:50 pm
why? what error do you get.
do you mean the program doesnt work or the link?
anyways, you can try this MP3 Player Utilities 3.68
Old 4th Jan 2007, 11:29 am
Like when I click start..nothing happens..And when I open the disk tool, It says device not connected...but then it pops up anyway..slider won't move..D=
弱々しいカルヴァン
Old 4th Jan 2007, 1:56 pm
caLVin, The Disk Tool is not going to work if it does not detect the device.
Does the player show up in Explorer when connected?
Are you having any other problems with the player?
Old 4th Jan 2007, 3:46 pm
It shows up on explorer I've used it for like 1 wek already and it's working great..no problems..yet..Just the disk tool thing.
弱々しいカルヴァン
Old 5th Jan 2007, 5:03 am
thats strange. if your computer is detecting it, i wonder why the disk tool isnt
Old 5th Jan 2007, 7:13 am
caLVin , what chipset is your player running off? If it isin't the Actions ATJ series, the Disk Tool would not be able to detect and format it successfully.
However, you can try the HP Format Tool, and it should be able to format almost all usb flash drives. http://www.mympxplayer.org/format-ut...-mb-df127.html
Old 5th Jan 2007, 10:50 am
Ok thanks! =) I would be shure to try that. I know my mp4 is rockchip.
弱々しいカルヴァン
PROBLEM TO REMOVE AN MP4 hacking dj_chiquito Support and How To 19 27th Apr 2011 11:52 pm
Method of Installing the firmware???plz urgent help!!?? dogarsahab Dead Players 0 12th Aug 2008 4:21 am
Using s1clone as a backup method Husker Support and How To 5 3rd Nov 2007 7:10 pm
Any other method of checking out the true memory of mp4? monkeykingy General Discussion 1 26th Oct 2007 5:16 pm
Sound is hacking and sometimes delayed like an echo...help! achillez Support and How To 5 9th Oct 2007 10:10 pm
