-   -   Er alot of questions =/ Need help!!~ (http://mympx.org/forum/support-how/35825-er-alot-questions-need-help.html)
caLVin 4th Jan 2007 4:48 pm
Hey everyone,
Have alot of questions to ask =/ :oops:
:arrow: 1. About the de=hacking method..The disk utilities cannot detect my MP4 but I've put songs on it for 1 week and is working great just the disk utilities cannot detect the device. Also, when I press start, nothing happens..like under the partition and encrpt tab, when i press start..nothin happens..I have to be on the format tab to press start bu tit just FORMATS it..I really really need help on this because my MP4 is startin gto duplicate files.
2. If my MP4 only has 1 game (it probly has more hidden ones) , doesn't have a TelBook and i put a new firmware into it with the TelBook feature and other games like minesweep etc. , would that CREATE a new game and create a TelBook feature into it?
3. Is there a way to unlock all the games on your player?
4. I can't find my firmware anywhere..I don't think anyone has the same MP4 as me D=..I can't even figure out waht firmware my IS. Basically question 2 and 4 are kinda related.
5. ..HELP :!:
To the people that actually will help me..THANKS!!~ =D
tadad1 4th Jan 2007 5:29 pm
caLVin, Upgrading the firmware will most likely kill your player and if it is using one of the 9.0.XX series firmware you may not be able to recover it if it dies.
It is not possible to add or unlock the telbook or xtra games.
Try using this Low-Level Format tool, for some reason it only seems to work if you run it twice.
http://uploaded.to/?id=ful2ny
caLVin 4th Jan 2007 6:56 pm
Thanks. Do you have any idea to help me find out what my firmware is?
caLVin 4th Jan 2007 7:03 pm
AFter iformatted it, there's not difference and it says i have to creat partitions and format it?? huh?? and the readins are still the same. it's 981 mb..after formattingand the disktoolutility won't detect it.
tadad1 4th Jan 2007 8:17 pm
caLVin, Go to the Settings menu on your player and there should be an entry for "Firmware Version"
lattesurf 5th Jan 2007 7:16 am
caLVin , i would suggest that you verify your firmware version before you proceed with any firmware related tasks.
Your chipset might not be an Actions chip, as in your other thread you are able to use the player fully, but not able to get it detected by the Disk Tool. http://www.mympxplayer.org/de-hackin...rk-vt3300.html
caLVin 5th Jan 2007 10:49 am
My chipset is a Rockchip. I know that for shure
lattesurf 5th Jan 2007 12:20 pm
caLVin , since your player is Rockchip, there is basically nothing much you can do to your player.
With regards to your questions:
1. MP3 Utilities are only for Actions chipsets.
2. Firmware updates are NOT recommended with the Rockchip. Once killed, it is extremely difficult to recover, and usually needs to be factory reset.
3. There are not many softwares for the Rockchip, so unfortunately i don't think you can unlock any games.
4. Not many softwares to extract any working firmwares from Rockchips.
So basically, just enjoy your player as it is.
caLVin 5th Jan 2007 2:36 pm
Ok thanks for the attention anyways =) So even though my player is hacked, I can't do anything about it anymore?
lattesurf 5th Jan 2007 9:31 pm
caLVin , generally the Rockchip players are not hacked. The majority are the Actions players which are commonly being hacked.
However, you can use the Hp Format Tool to format your player instead.
