Update the firmware Help!!!!
Old 6th Jan 2007, 9:18 pm
Default Update the firmware Help!!!!
Hello to all, I have a doubt. I want to update the firmware to change to the present for my player but not which is compatible
(I feel I do not speak it sufficient english sorry )
As is firmware compatible but present?
This is my actual firmware:
PMA300_006 2005/11/04
RYJ-3.5.35 2005/12/16
This is the player:
Do I need much information?
Español:
Hola a todos, tengo una duda.Quiero actualizar el firmware que tengo por el mas actual para mi reproductor pero no se cual es compatible ( lo siento mi no se mucho ingles)
este es mi firmware actual:
PMA300_006
2005/11/04
RYJ-3.5.35
2005/12/16
Necesito mas información?
Old 7th Jan 2007, 1:42 am
_AXS_,
You shouldn't need to update your firmware. What you can do is extract the firmware from your player, then MODIFY it to have the images you want then reupload back onto your player. This will be SAFER than using someone else's firmware as it might cause your player to die.
There is a sticky on the [Mods and Themes] section of this forum which will guide you through the steps. Try following those and if you have problems, let us know, we are here to help out one another .
Firmware update Oman Support and How To 0 4th Aug 2008 11:48 am
I need to update firmware gaudier Support and How To 2 29th Oct 2007 1:28 pm
Update of Firmware ajaybcd Dead Players 1 2nd Sep 2006 3:23 pm
firmware update milindbendre Video related 1 4th Aug 2006 7:01 am
Firmware update or not cherva Support and How To 5 4th Jul 2006 4:58 am
