USB cable pin outs
Old 7th Jan 2007, 9:25 pm
Default USB cable pin outs
if your cable is not working and still can be repaired cozf you dont have money to buy one but have the tools for connecting wires,,check this picture to determine the pin outs of yor cable..there are two types of mini cables shown i hope this is useful to you,,,..
wondering how this is useful?
if your player seems well but the computer cannot recognize your player..well its the cable dude..best thing to do is check the connection between the two ends..the pictures shows you the detailed information on the pin outs..you can use an ohmeter at your multimeter selector and check if the two ends has a continuity (connected by conduction)..
and if you want to make a usb cable out of a wire and connectors which is sold at electronic stores..you can make one by soldering it the right pins..well you must be knowledgeable enough to do this..it will cost you less in doing this you must take precautions..if you know the risk and know what your doing, then go ahead, well, if not then buy a more expensive yet cheap enough USB cable..
the image came from books.. that said the pin out is in general form (the same in every unit)..
p.s. in case you want to buy one but you dont know the name..well its in the picture..stop describing a product with your own words specially on an SQL..he3
to download this picture here is the link
http://uploaded.to/?id=vubvx2
Old 8th Jan 2007, 12:48 am
Excellent, saves me time probing pins
Old 10th Jan 2007, 8:42 pm
amnman thnx
Old 12th Jan 2007, 1:45 am
Default Re: USB cable pin outs
Edited post.
Some players use 5 pin and some use 4 pin and there are different styles of each type.
http://electronics.search.ebay.com/5-pin-mini-usb-mp4
http://electronics.search.ebay.com/4-pin-mini-usb-mp4
See http://forum.s1mp3.org/viewtopic.php?t=991 for more info.
Remember the old days? When usb was simple.
Old 12th Jan 2007, 10:31 pm
Originally Posted by jctoad";p=&quot View Post
If all else fails.....
Should be able to get one for $5 or less including shipping.
nice one!
Old 22nd Jan 2007, 2:08 am
5 pins really have 5 pins but only 4 are used so there is no problem...
Old 22nd Jan 2007, 5:30 am
MPx-a-lolics Anonymous
good work arviverona. its very useful and i am sure it will help the members a lot
Old 24th Jan 2007, 5:11 pm
thnx deepakrr
Samsung yp-z5 USB data Cable//losing usb cable P@inKuler Support and How To 2 5th Feb 2009 1:38 pm
USB cable Zephyron Support and How To 3 9th Mar 2007 4:30 pm
Need a USB cable confused_mp4_owner General Discussion 8 9th Dec 2006 8:43 pm
usb cable pigdogboy Dead Players 0 6th Oct 2006 7:48 am
Usb Cable eldiablo04 General Discussion 4 27th Jul 2006 10:12 am
