best way to charge battery
Old 11th Jan 2007, 7:09 am
Aiu Aiu is offline
Default best way to charge battery
Hello,people
What's the best way to charge battery of the mp3/4 player?Using the USB on the computer or using the AC adaptor?
My mp3 player takes one hour to fully charge and plays music continually about 5h.Itīs normal?
Thanks for your attention
Old 11th Jan 2007, 10:17 am
mine are equal when i charge from wall charger, when i charge from USB i can't tell when the battery is full charged because a glitch in firmware. regards from Colombia
Old 11th Jan 2007, 12:14 pm
Aiu, Most of these players have lithium polymer batteries which preform better and last longer with lots of quick recharges. Draining the battery completely before recharging places more stress on the battery and will shorten it's life. You should avoid charging for longer than 3-4 hours at a time.
The adapter is best used only if you are unable to charge via USB.
Old 11th Jan 2007, 6:20 pm
charging via wall adapter is not the best way but sometimes the fastest..a wall charger is vulnerable to power fluctuation and other voltage abnormalities that may soon affect your player..i advice that as much as possible and if you are already using your computer..you might harness the time of charging your player..coz the power supply of your computer has many protection against abnormalities in the power..like hums and fluctuations...
Unibit X-320 Player - How do I charge battery? TyphoonTycoon Support and How To 1 24th Nov 2007 8:50 pm
18 Hours Continuous Music Play on a Single Battery Charge. tadad1 General Discussion 0 17th Nov 2006 7:40 pm
how do i charge the battery peruvianfreak250 Support and How To 1 18th Sep 2006 5:59 pm
Battery Charge Problem? General Discussion 32 31st Jul 2006 9:47 pm
