-   -   Problem with external speaker. (http://mympx.org/forum/support-how/36008-problem-external-speaker.html)
Spartan-088 14th Jan 2007 3:43 am
I've got a problem with the external speaker on my mp4 player. I can't turn it off. I thought that i would be turned off when I plug in the earphones but it is still on. Is there some way to shut it off? It's kind of annoying.
P.S. If it helps, I have this mp4 player.
tadad1 14th Jan 2007 6:51 am
Spartan-088, I have a similar player and I have to press the REC button for 2 or 3 seconds to turn the speaker on and off.
Spartan-088 14th Jan 2007 7:33 am
Re: Problem with external speaker.
I can't belive it was this simple. Thank you. :D
rikkjaard 2nd Mar 2008 9:53 am
Hello, i have a iWin MP4 player, model i-B820M, with rockchip (i believe...)
I can't turn off the external speaker. There is no record button on my player and i don't know to make it!!!
Sorry for my english, thanks for help me.
