help with my mp4 player
Old 17th Jan 2007, 4:20 pm
xme xme is offline
Default help with my mp4 player
I received this mp4 player from my friend. No manuals, no info about it.
Front pic:
Port pic:
It has two ports, a 2.5 audio port for headphones and some type of USB port.
It came with a wall charger with a mini-USB connection, yet that doesn't fit the USB port. <=it's too big.
I also tried my micro-USB cable, doesn't fit either.
Any help appreciated.
Thanks in advance.
Old 18th Jan 2007, 12:38 am
Default Re: help with my mp4 player
Edit: Sorry impeeza is correct about size of cable.
It is best to charge it from the usb port and not the wall adapter.
http://cgi.ebay.com/NEW-STYLE-WHITE-1GB-MP3-MP4-FM-PMP-PHOTO-MOVIE-PLAYER_W0QQitemZ300071597485QQihZ020QQ
Gives some details on it. You will have to check yours to see what size the memory is.
Old 18th Jan 2007, 8:57 am
you need a special USB cable the MPx Players use one different to all others USB conectors, try:
Search for "mini usb mp4 player cable" on eBay
Old 18th Jan 2007, 11:45 am
For more explain see:
http://forum.s1mp3.org/viewtopic.php?t=991
Old 18th Jan 2007, 10:39 pm
xme xme is offline
thank you, i'll look into those.
my friend actually might have one, so he'll get back to me.
thank you though.
