Problem with Radio / Record.
Old 18th Jan 2007, 5:49 am
Default Problem with Radio / Record.
Hello,
I've just bought a 2GB MP4 in ebay, from HongKong. It's similar to this one, but in white:
http://www.buyanything.ca/mp3_player...ck_278x278.jpg
I've been testing it, it's real 2GB, mp3 works, amv works, radio is ok. But when i'm on Radio, if i select Record in the menu, it says "Please wait..." and then it reboots.
Any idea?
Thanks!
Lino.
Old 18th Jan 2007, 8:55 am
Default Re: Problem with Radio / Record.
Originally Posted by azraelpc";p=&quot View Post
Hello,
Any idea?
Thanks!
Lino.
May be a fimware corrupt, if still in warranty return to seller, if not you could try one from download section but BACKUP YOURS first.
Old 18th Jan 2007, 9:58 am
azraelpc , try extracting, repairing, then re-flash your current firmware.
Extraction & Repair guide here http://www.mympxplayer.org/how-to-ex...tool-vt66.html
Re-flash guide here http://www.mympxplayer.org/how-to-up...ayer-vt46.html
See if this solves the problem. If not, contact your seller for an exchange, might be some faulty parts/connection.
Old 18th Jan 2007, 10:55 am
Que Que is offline
Have you removed the standard record folder? If so, recreate it. You might want to try a defragmentation of the player through windows. If to no avail, try if the problem is still if you record at a low bitrate, say 128 kb. If this goes try 192 kb, and so on.
Old 19th Jan 2007, 2:01 am
I'll try this afternoon. Thanks!
Old 22nd Jan 2007, 2:02 am
Finally, i fixed it without flashing. I simply set the rec type to MP3 and it worked... Don't ask me why :P
radio problem jithendra Support and How To 6 28th Mar 2007 8:09 am
Memory problem, no radio ???? jellalit Support and How To 12 19th Dec 2006 9:09 pm
Radio problem gkatsogr Support and How To 7 29th Sep 2006 3:35 am
FM radio problem flik Support and How To 2 2nd Sep 2006 4:47 am
Can't record from Radio oxtros Support and How To 0 13th Jul 2006 9:41 am
