24th Jan 2007, 9:31 pm
Forensic , you can also link your paypal account to your bank account directly.
From the looks of it, it seems like the battery is starting to show signs of dying. For charging, usually the player gets slightly warm, rather than hot.
i would suggest that you use your computer to charge the player and avoid using the AC adaptor. The current supplied by the AC adaptor is much higher than the computer USB.
.::Lain::. , that's about the playtime your should get from a full charge. However, like i've mentioned, try to avoid using the AC adaptor and use the computer's USB as far as possible. It might take a little longer to charge, but it's better for the battery.
