how to find the firmware model
Old 25th Jan 2007, 8:43 am
Default how to find the firmware model
Hi there!
I need to know how I can know my exactly model to upgrade the firmware.
the product is a 4gb mp3mp4player
http://cgi.ebay.es/ws/eBayISAPI.dll?...1590&rd=1&rd=1
The firmware info (surfing in the mp3mp4player) is:
ACT2097_S72_1
2006/04/25
9.0.50
2006/10/30
Devic name: S1 Mp3 player
Productor: Wilson Co. Ltd.
Itīs normally than the large files (more than 100mb) could have problems transmissions?
Some times the tree folders crash, and duplicate the folders and files... what happened?
There is a new version of the firmware? which is the exactly name/number?
Thankyou for your help
cheers
malak
Old 25th Jan 2007, 11:04 am
Default Re: how to find the firmware model
Your firmware is ok. You have a hacked player! Please follow the instructions in this thread to find the true size of your player.
Old 25th Jan 2007, 2:04 pm
Thanks for your soon request!
Probably I had a hacked unit....
what about the refunds in ebay...can I get back all my money?
thanks again!
Old 26th Jan 2007, 2:45 am
MPx-a-lolics Anonymous
you can always try filing disputes and emailing the seller for a refund. hope you get it.
Old 4th Mar 2007, 2:12 pm
hello,
i have a mp4 player same with malak's
i tried firmware upgrade and it dumped.
i need original firmware for my player.
anybody help me please?
firmware info :
ACT2097_S72_1
2006/04/25
9.0.50
2006/10/30
link : http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=250063542456
Old 4th Mar 2007, 7:29 pm
acihatholta , try all the v9.0.xx series firmwares in the downloads section here http://www.mympxplayer.org/actions-9...mare-dc37.html
If none of these work, try contacting your seller and see if they have the firmware file to send to you. Also search the CD that came with your player, sometimes the firmware is inside, it should be in .fw or .bin format.
Old 5th Mar 2007, 2:34 pm
thanks for your answer lattesurf
i tried all 9.0.xx vers. f/w.
and i can't contact to seller ebay says -no longer registered user-
i have a dead player now.
thanks
Old 3rd Apr 2007, 10:12 pm
Hi there!
the product is a 2gb mp3mp4player
Digital Player
LX27007_B
2006/11/07
ACT_v9.0.4x
Is it normal that large files (more than 100mb) can't play?
Old 4th Apr 2007, 12:31 am
marioch , your problem with the folders and files seems to be symptoms of a hacked memory chip. Format your player with MP3 Utilities Disk Tool here http://www.mympxplayer.org/how-to-re...ck-vt2400.html
Regarding firmwares, never update with another firmware, even if the version number is exactly the same. As you would most likely brick your player. Unless your player is dead, you should never flash in firmwares.
What's model this MP4? For firmware YASLICOCUK38 Firmware 1 5th Jan 2010 3:42 am
model TM-620 firmware radio_ak1025 9.1.52? izzusan Firmware 1 30th Oct 2008 2:20 am
Find model and firmware of MP4-Player? Programie General Discussion 1 25th Jun 2008 10:34 am
How to get the firmware for Model:A1137 domnicxavio Support and How To 0 13th May 2008 10:14 am
Need firmware for this model... Frm Dead Players 1 16th Jul 2007 8:41 am
