problem selection songs
Old 26th Jan 2007, 4:32 am
Default problem selection songs
Hello, I try to explain the problem:
example 1:
I have saved 50 songs in the reader mp3, want to listen to the n°26, I select number 26, I crush menu in order to select it, and instead leaving the n°26 it always leave the n°1.
Example 2
I have saved 5 album various in five cartelle various in the Mp3 reader. I want to listen to the song n°5 of the N°3 album. Within in folder 3, I select it with the menù key, I select song 5 with the menù key and instead leaving the selected song, the song n°1 of the folder set offs n°1. is this the problem.
I can not select song.
How to resolve it?
thanks Luca
Old 26th Jan 2007, 5:04 am
sonicexenia, Whilst in the music function press menu and select repeat, make sure it is set to 'Normal"
Old 26th Jan 2007, 5:44 am
thank
I have already made all this, but the problem remains.
Whi?
Sonicexenia
[solved] Video selection only says "Empty Disk" satdog75 Video related 3 27th Dec 2008 10:07 pm
A tempting selection of new players from ebuyer geostar General Discussion 4 19th Dec 2007 11:46 pm
help in selection of firmware krates98 General Discussion 2 17th Dec 2007 4:53 pm
Songs deepakrr Support and How To 6 20th Dec 2006 9:01 pm
songs duplicate and only 25 songs play cardinalbird Support and How To 4 6th Nov 2006 8:24 pm
