26th Jan 2007, 8:15 am
smoo7h , as you have said, the S1fwx 3.1 only supports upto v9.0.43 at this moment.
So there is nothing much you can do to the firmware whatsoever.
Just enjoy your player as it is, and do not try to update with any firmwares, you will only most likely kill you player.
