Help, my player didn't charge!?!
Old 2nd Feb 2007, 4:05 am
Default Help, my player didn't charge!?!
Hello
I've bought an 2GB MP3/MP4 player, this one:klick here
Everything is OK but: I've tried to recharge the player. i've connected the player with my PC. On the player i could see the symbol that show me that the player get charge. After two hours i reconnect the player and turned it on. after 5 seconds on the display i could see the symbol that the battery is empty and the player turned off.
where is the error? what could i do?
end33
Old 2nd Feb 2007, 4:43 am
end33,
Is the player turned on while charging?
Are you using a USB hub?
Try another USB cable.
Old 2nd Feb 2007, 9:53 am
Default Re: Help, my player didn't charge!?!
i use the usb port from my laptop, without an hub.
i could turn the player on when he is connected to the pc but the battery didn't charge.
where is the error? the cable? but why can i turn the player on when it is connected to the pc.
end33
Old 2nd Feb 2007, 11:14 am
end33 , the problem could be a faulty USB cable. So try another cable if you have a spare.
However, since you are able to use the player whilst connected via USB to the computer, and it turns off after you disconnect the cable, likely it is either a faulty cable, or faulty battery, or faulty charge regulator.
Help my MP4 cannot charge - S1 MP3 PLAYER tanwill Support and How To 16 8th Oct 2007 1:33 pm
Player won't charge at all frustrated Dead Players 2 30th Dec 2006 8:15 pm
I cant charge my MP4 player okanaydin Support and How To 4 26th Nov 2006 1:42 pm
My player will not charge!!!! WackyZ Support and How To 1 25th Nov 2006 7:09 am
New mp4 player wont charge. minxy Support and How To 3 11th Oct 2006 6:11 pm
