battery charging
Old 8th Feb 2007, 1:55 pm
Default battery charging
how long do you charge your mp4 for?
Old 8th Feb 2007, 2:14 pm
I use lots of quick topup recharges and never let the battery drain completely.
Old 9th Feb 2007, 12:04 am
MPx-a-lolics Anonymous
lol i only charge when the battery is drained.
i let it charge full and leave it charging for an hour more
Old 9th Feb 2007, 5:06 am
Que Que is offline
Same here. Only new batteries, I load/unload them 2 or 3 times, before I go to the quick recharges. These topup recharges seem the best way to preserve li-ion batteries. Now I have lithium-polymer batteries, shouldn't matter now. But I still keep them full. You'll never know when you have to pick up your bags and run!!! (meaning I could be out to do something elsewhere for some time, and a dead player is one of the worst things that can happen to me when on a bike or a train or a plane)
Old 9th Feb 2007, 11:13 am
I just attack my MP4 to my PC when ever I'm not using it. It means I can access it and update it with music and what not with out going through pluging it in and all that crap and its allways fully charged.
Old 10th Feb 2007, 5:32 am
Same as tadad1 and Que.. i seem to get maximum usage time from little top ups
[hr:43af44b395]
Old 25th Feb 2007, 11:17 pm
Default Re: battery charging
Something is wrong with my player if it only takes an hour or two to charge. I waited over an hour only to see it at half. Then almost another hour and no change. I think I'll sell it on ebay or just give up and buy another mp3 player. These things are crap.
Old 27th Feb 2007, 2:47 pm
My player will charge all day while plugged into a PC, I also have the USB/electrical plug charger which charges within an hour or so. However the battery life on my player (purchased in Jan 07) is less than 3 hours per day...which is a bit inconvenient as my commute to work and back is 2.5 hours per day!
only the image connected and the battery charging pheonix1 Support and How To 2 26th Jun 2008 12:35 pm
help with the charging of battery for my mp4 raweclaz Support and How To 2 23rd Apr 2008 8:02 pm
took 24hr to fully charging the battery sarden General Discussion 2 15th Feb 2007 4:21 am
Charging 3.6v Lithium Ion Battery? buts101 General Discussion 3 7th Feb 2007 6:52 am
IPod Clone not charging - Now battery is dead! jeromeof Support and How To 1 26th Dec 2006 6:53 am
