-   -   [Fix] Bianca MP4 fix for my restart issues (http://mympx.org/forum/support-how/36885-fix-bianca-mp4-fix-my-restart-issues.html)
VegasPlayer 22nd Feb 2007 9:21 pm
I just bought a Bianca player from Uxcell and it was restarting with the hourglass. At first I thought it was static doing it but the whole case is plastic and non conductive.
I opened it up and checked it out for bad connections but it is damn tight in there and nothing was disconnected except for a battery lead that was never attached in the first place. After screwing around with it for a few minutes I noticed it worked out of the case but had the same problems when I put it back in. Well it comes to be a piece of tape was put off center to the speaker that had a metal backing. So I put a piece of tape on the back of the speaker over the metal and it fixed all the problems.
BTW I noticed the player has a Li-Ion Polymer battery built in.
deepakrr 23rd Feb 2007 8:00 pm
thanks for sharing. this will help a lot of people. :)
admin 24th Feb 2007 4:46 pm
Thanks for sharing this with us all VegasPlayer.
Are you able to take some photos with your tip? That would be very helpful for others to know.
VegasPlayer 24th Feb 2007 10:10 pm
My digital camera is not working so I don't have any pictures.
It was a really easy fix, just stick a piece of tape on the back of the speaker. They had the tape stuck offcenter over the Circuit Board.
