ATJ2091N 9.0.50 How to extract the firmware?
Old 23rd Feb 2007, 10:02 am
Default ATJ2091N 9.0.50 How to extract the firmware?
Hello!
I just bought a mp3 player 2Gb with ATJ2091N 9.0.50 (colortext)!
I want to extract the firmware.
I have a same dead mp3 player and I want to use the firmware from the new player!
I use "s1fwx_v31" for the extract and the MP3 Player Utilities 3.68 (upgrade tool) for the upgrade.
Unfortunately, the upgrade tool says that "the firmware file is invalid".
I think that the "s1fwx_v31" doesn't extract the full firmware file from the mp3 player.
How can I extract the correct firmware from ATJ2091N 9.0.50?
If I download the correct full firmware from the mp3, after that I can to give to you...
Thank You
Old 23rd Feb 2007, 12:02 pm
Que Que is offline
You can't extract/repair/flash any firmware from 9.0.48 and up because the program for it needs an update before it can work with those firmwares. You have to wait for that.
Old 23rd Feb 2007, 10:36 pm
oh! I didn't know that.
So, I'll waiting for an update of the extract tool...
How can i extract its firmware.. any help? kimbz920 Support and How To 2 7th Dec 2008 1:54 am
Extract firmware 9.1.52 Than and as? Sever76-1 Support and How To 1 27th Oct 2008 9:38 am
How to extract 9.1.52 firmware nywww Support and How To 16 19th Mar 2008 6:16 am
Can You Extract A firmware 9.0.48 baistosh Support and How To 1 4th May 2007 8:40 pm
how can i extract a 9.0.48 firmware? botti Dead Players 1 10th Feb 2007 2:05 am
