need help with MP3/MP4 player
Old 28th Feb 2007, 5:20 pm
Default need help with MP3/MP4 player
I bought an MP3/MP4 player from ebay from dibsubs (dibsubs?).
The information on the back says
MP3/MP4
FC CE Tested to Comply
With FCC Standards
FOR HOME OR OFFICE USE
Then it has three little icons:
MIC, MP3, and USB
After that it has the headphone jack, MIC jack, and USB port marked.
Now, here's my problem:
At first, I thought it wasn't charging, but then I found I had needed to keep the power switch in the on position. Aha! It is now charging! I checked it just a few minutes into charging to test that it wouldn't turn off immediately and it was successful in running for just about a minute. Good.
However, I've been letting it charge for a good few hours now, and now it will not power on no matter what I try.
I've tried connecting it to the USB port of a laptop, power switch on and off - and it does not power on nor does the computer recognize it as a USB device (as it did earlier). I am not certain what to do if there is something to do. I just got it a few days ago.
Bridget
Old 28th Feb 2007, 7:12 pm
It might be in sleep mode.Hold down the play button.
Old 28th Feb 2007, 11:00 pm
I tried this when trying to turn it on - holding the play button and holding the menu button - nothing happened
