Memory problem
Hi all.
I have a problem with a S1 mp3 player. It is a REAL 1gb player but only shows 119mb free, i already tried to format and use the guide "How To: Removing Memory Hack" but there is not difference. Is there a solution? I'll be waiting for an answer. Thanks. |
I recon its a 128 meg player , just oepn it up an see what the chip is , its a bit of a coninsidence that its 119 which is what youd exprect from 128 meg chip normally.
SayNoMore,
I have to agree with lite. It seems like you have a 128MB chip player instead of a 1GB. It has been known in the past that even 1GB players have been hacked! I too would suggest you open the player and find the printing on the chip and compare it to see what the real size is. Is the player still in warranty? |
Re: Memory problem
Finally it was a hacked player, but I changed it for another one. Thank you all.
| All times are GMT -7. The time now is 8:25 pm. |
