Teclast 2GB C260 Memory Problem!.
Old 2nd Mar 2007, 9:26 pm
Default Teclast 2GB C260 Memory Problem!.
I ordered more Teclast C260's. This time the 2GB's and on 1 of them the flash memory shows 1984/1988 used. And there is nothing on the player yet except the folders ie. AVI, MP3, EBOOK and so on. Anyone know how to fix this. I even removed the sample videos and pictures and it still reads the same. Tried a format as well. Thanks!.
Pocket-Nano
ChiPod's Rule!
Old 2nd Mar 2007, 10:03 pm
Pocket_Nano , when you connect the player to the computer and go to My Computer, right click on the player's drive and select Format.
Then format it using Fat file system.
See if this solves the problem.
Old 2nd Mar 2007, 10:34 pm
Didn't work. I tried to format it in FAT and also FAT32. It still is the same. Any other suggestions?. Thanks!.
Edit: I also noticed that each time I format it it shows 1 more mb as being used so now it shows up as 1987/1988. This is crazy.
ChiPod's Rule!
Teclast C260 usb problems fu4f043j9g Support and How To 2 3rd May 2009 4:28 am
New firmware for teclast c260 clone? niel68 General Discussion 4 20th Jan 2009 1:45 pm
Teclast C260 Look-Alike Question knob General Discussion 1 11th Oct 2007 6:11 am
Teclast c260 clone mueslee Dead Players 0 24th Sep 2007 4:25 pm
Teclast C260 Pocket_Nano General Discussion 5 13th Feb 2007 10:37 am
