Would a 3.7 V mAH Ipod Nano battery work in my nano clone?
Old 3rd Mar 2007, 5:48 am
Default Would a 3.7 V mAH Ipod Nano battery work in my nano clone?
The reason I ask is because the Ebay auction for the battery states that it's for the Ipod Nano 1GB, 2GB and 4GB and my clone is a paltry 512mb. Do you think it would still be compatible and work okay?
This is the exact player I have - your standard 1st gen nano clone: http://www.pconline.com.cn/digital/a...09/873734.html
And this is the battery I'm eyeing on Ebay: http://cgi.ebay.com/NEW-400mAh-Repla...QQcmdZViewItem
The current battery life completely blows so I'm hoping a new battery might improve it.
Thanks for your help everyone.
Old 3rd Mar 2007, 7:31 am
Uxcell also sells replacement batterys for the Apple Nano. You can check the Uxcell website for the excact size of the iPod Nano battery, then open your player and compare the size.
Old 3rd Mar 2007, 1:09 pm
Default Re: Would a 3.7 V mAH Ipod Nano battery work in my nano clon
Changing the battery has nothing to do with mem capacity, so you can use the battery in that auction (and it looks like a goody). You just need to measure the space your current battery fits in, then ask the seller if he'll give you exact measurements of his battery and see if they can work togther.
Old 3rd Mar 2007, 2:38 pm
Ahhh so the memory card has nothing to do with it. Okay thanks, I will crack it open later to measure dimensions, without destroying it I hope! Thanks for your advice. :mrgreen:
Old 3rd Mar 2007, 2:47 pm
And to replace a battery, is it necessary to have a "searing iron tool". One auctions says you need this - but I'm pretty sure I haven't got one. And even the Uxcell battery replacement manual says you must "weld the anodes and cathodes" and I don't have welders lying around either. Does anyone know for sure what tools you need, aside from the 2 plastic screwdrivers the battery comes with? Thanks!!
Old 3rd Mar 2007, 4:06 pm
What they are talking about is a soldering iron. Use a low power one, 25-30 Watts.
The tools that come with it are only needed for real ipods. They are plastic pry bars.
See http://www.uxcell.com/public/mp4/rep...um_battery.pdf
Old 3rd Mar 2007, 5:09 pm
If you have never soldered anything before, I suggest you read a few guides (Google "how to solder"). Here is a nice video tutorial on how to solder:
How To Solder Video
You may also want to practice using an old circuit board to get the hang of it.
Old 6th Mar 2007, 7:57 pm
Thanks for all the advice! The soldering video will definitely come in handy when I decide to upgrade the battery of my new 2nd generation clone, of which I am eagerly anticipating the arrival!
Old 6th Mar 2007, 8:32 pm
If that is a second generation nano clone, you may need those plastic pry bars after all.
"Windows Update might require an update before you can install updates for Windows."
Volume doesn't work on my Nano Clone frostiex Support and How To 1 13th Sep 2007 8:27 pm
iPod Nano Clone Battery Life aurelio General Discussion 5 30th Mar 2007 5:34 pm
[Solved] Will a 400mAH ipod nano battery fit & work t.powley General Discussion 4 28th Nov 2006 11:29 pm
2GB Nano-clone doesnt work properly mrpragay Dead Players 8 23rd Oct 2006 7:38 am
Nano Clone ipod 1GB -- battery change jasstone General Discussion 3 13th Jul 2006 5:53 am
