firmware extract???
Old 3rd Mar 2007, 10:36 am
Default firmware extract???
Why do I need to extract my firm ware. Ive seen threads on how to do it. but why do I need to do it???
Old 5th Mar 2007, 12:44 am
Camaro,
If you extract you firmware, then you have a copy of the firmware (aka the 'brains' of the player) as a file.
If you have a support firmware version, you can then edit it, put in your own images, change the text etc then reupload back onto your player. This then gives you the opportunity the customise and theme your player's menus etc.
Also, if you have the firmware of your player, it means you can use it as a backup in case you decide to flash it with another firmware instead (would NOT recommend this).
How can i extract its firmware.. any help? kimbz920 Support and How To 2 7th Dec 2008 1:54 am
Extract firmware 9.1.52 Than and as? Sever76-1 Support and How To 1 27th Oct 2008 9:38 am
How to extract 9.1.52 firmware nywww Support and How To 16 19th Mar 2008 6:16 am
Can You Extract A firmware 9.0.48 baistosh Support and How To 1 4th May 2007 8:40 pm
how do I extract my firmware or is it even possible? squall458 Support and How To 1 4th Mar 2007 10:35 pm
