A little amv coverting help please
Old 4th Mar 2007, 8:00 am
Default A little amv coverting help please
I have a player with a 1.8" screen. But it seems there is no easy way to convert to 160 120 (at 16 fps), so here is my question; can it only play videos that are 160 120? or can it play other more common video sizes? I don't mind if it doesn't fill up the screen I just want an easy way to put videos on it.
Old 4th Mar 2007, 9:18 am
Your player should be able to do 96x64, 128x96, 128x128, and 160x120. I uploaded AMV Convert Tool 4.0 that I set up to convert to 160x120, with the exe hacked to allow you to select the audio bitrate. You can also find it here.
Old 4th Mar 2007, 3:22 pm
Default Re: A little amv coverting help please
Thank you, that helps a lot, sorry if that was a bit of a noob question but I suck at this stuff
Old 4th Mar 2007, 3:51 pm
When I covert videos with your converter the sound doesn't work, it sounds all fuzzy, is there any thing I can do about that, thanks
Old 4th Mar 2007, 6:08 pm
OK its working now but only when the video I am converting is quicktime format, so I will just have to covert my non quicktime files. thanks for all your help
Old 4th Mar 2007, 9:15 pm
Sounds like you are missing a codec. Try installing the K-Lite codec pack. That may solve your issue.
Old 4th Mar 2007, 10:30 pm
I Have an mpx player also with a 1.8 screen. Where can I find or upload the lastest version of amv converter that can convert 120x160 resulotion, coz my amv converter convert only 96x64, 128x96. Plzzz.. ^_~ help!
Old 4th Mar 2007, 10:35 pm
Your player is 1.8 screen you can put 96x64, 128x96, 128x128, and 160x120 on your player.
Old 4th Mar 2007, 11:04 pm
In the second post of this thread.
