radio problem
Old 5th Mar 2007, 4:47 am
Default radio problem
sir ive recently bought an mp4 player wit 1g capability
iam happy wit the way it performs but still i cant play my fm even if it is connected to earphones.
can u pl help me to solve this problem
please
will firmware update be a solution
Old 5th Mar 2007, 7:59 am
The fm radio is a seperate chip , so either the chip is faulty and your player will not be damaged atall , or your headphones arnt making a proepr connection or you have no chanels where you live/ havnt scanned proeprly/ cant pick up the chanels with a small ariel.
Old 5th Mar 2007, 1:12 pm
Firmware update would not be a good solution.
Does the radio mode work at all?
Make sure the radio is not set to Japanese band.
"Windows Update might require an update before you can install updates for Windows."
Old 20th Mar 2007, 1:43 am
the radio does work sir but the signal is not tat great its only givin 1 chanel out of 10
tanks for the reps can u help me out
Old 20th Mar 2007, 1:44 am
thanks for the reply can u help me out more
Old 20th Mar 2007, 4:33 am
jithendra , when in the FM Radio program, press Menu and select Search Level. Next decrease the value to 1, then try scanning for radio reception again. If it does not work, set the Search Level to the maximum instead and search again.
Old 28th Mar 2007, 8:09 am
sir there is no such option
can u help me
Full Metal Platinum 1.5 - Radio problem womblebongo General Discussion 6 5th Mar 2007 3:46 am
Problem with Radio / Record. azraelpc Support and How To 5 22nd Jan 2007 2:02 am
Memory problem, no radio ???? jellalit Support and How To 12 19th Dec 2006 9:09 pm
Radio problem gkatsogr Support and How To 7 29th Sep 2006 3:35 am
FM radio problem flik Support and How To 2 2nd Sep 2006 4:47 am
