-   -   My Mp4 doesnīt read Directories, WITHOUT A CARD. (http://mympx.org/forum/support-how/37143-my-mp4-doesn-t-read-directories-without-card.html)
polako71 10th Mar 2007 10:06 am
I have a NEXXTECH T9, 1GB 1.8" line in and SD/mmc..
The problem is that in Music function,, if i donīt use a Sd or mmc Card,, I canīt read folders..
and just in music,, In video voice or txt, no mather if there is or not a card,, it read them folders,,
And when i use a Sd card,, magically itīs read musicīs folders,,,(In both memories)
Anyone know why is that ??
FW core: 9.0.50
(sorry my english)
lattesurf 10th Mar 2007 6:05 pm
polako71 , though i don't own such an SD card player, but i think that it might be the way the firmware was coded. If so, there is nothing you can do about it. And i'll suggest not doing anything to the firmware as the recovery process isin't pleasant at all. Besides, v9.0.50 is still not support by the firmware extraction tool. So you'll have alot of problems looking for a suitable firmware.
polako71 11th Mar 2007 9:11 am
,,!! ,, I will try to use an older version of Fw (helped by korn88, the same player),, And if its fail,, i have the original one in the cd that comes with the player,,
lattesurf thanks for answering !
lite 11th Mar 2007 12:44 pm
Yeh ,k i still wouldnt do that , You can brick your player beond recovery , Well you will spend a long time shorting it anyway . I wouldnt attempt it.
polako71 11th Mar 2007 1:13 pm
Re: My Mp4 doesnīt read Directories, WITHOUT A CARD.
Wowowww,,, Haah,,, I almost kill my mp4!!
I have installed the 9.0.48 and,, start with a blank screen,, (without the "loading"), ,, my pc detects the disks,, but not working,, so,, i now using the original Fw,,,,
Thanks a lot, all of you !, ,
and,, again,, sorry my english, !;,
