Battery life/LCD brightness
Old 11th Mar 2007, 8:54 am
Default Battery life/LCD brightness
Hi, I have an Action chipset 1.8" player with the 9.0.5.0 firmware. My issue is that the battery life playing video, or just using the LCD, is very short. On a full change Video will play for about fifteen minutes.
The screen is very bright, and I wouldn't mind lowering the brightness significantly in order to extend battery life.
The problem is that under "LCD Set" in the setup utility I don't have a "Brightness" option. There are two items in the LCD Set menu, "black" and "exit".
FWIW, I have set "black" time to five seconds, sleep time to 30 seconds, and power off time to 60 seconds. So there's not much else I can do from a power conservation perspective.
What are my options here? I've seen postings indicating a manual firmware hack to adjust contrast, but nothing regarding brightness. Also, I see a lot of posts saying the 9.0.5.0 FW isn't yet customizeable.
What are my options here? Is there a firmware I can downgrade to that will allow me to adjust brightness?
Thanks in Advance,
- Great Site, BTW
Old 11th Mar 2007, 9:52 am
Me too and I have verision 9.0.48
Old 11th Mar 2007, 4:51 pm
Galaxieman & DAM2991 , currently the firmware extractor only supports upto v9.0.43, so both v9.0.48 and v9.0.50 are not yet supported.
Regards to firmware downgrade or upgrade, it is definitely a negative. Every firmware was specifically made for each batch of players. So another firmware with the same version number, likely it would not work on your player.
15minutes video playback time on a full charge is very little. Likely there is a problem with your battery and it does not hold it's charge well. On a stock battery, you should be getting a minimum of 2-3hours music playback or 1-2 video playback.
What i can suggest is to contact your seller for a replacement player. Alternatively, you can buy a replacement battery either from ebay or uxcell (someone posted about uxcell selling replacement batteries). But either way, open your player and measure the space allowed for the battery so you do not buy one that is too big for your player.
Old 14th Mar 2007, 12:06 am
hello DAM2991 I have the same version and it has 3 options under the LCD Set menu.
***Brightness
***Black
***Exit
version 9.0.48 well maybe there is still sumthin different about that.
to lattesurf: So the battery can be replaced? im so relieved 'bout that, i was just thinking what if the battery run out of life. or ill freak out and cannot use it anymore. thanks for the informations...
Please be advised that this conversation is recorded for quality control purposes we are also requesting the caller not to give a deep sigh during the conversation for it makes the agent irate. and he mean it!
Old 14th Mar 2007, 2:35 am
heheh.......tyro u can replace a mp4 battery by yourself..no hassle..regarding that u can set ur mp4's brightness.,,it is maybe coz different version...not all mp4 that have 9.0.48 and above have the sam feature..
like lattersurf say..firmware upgrade for 9.0.48 and above is not possible right now..
waiting for exam results.
Old 17th Mar 2007, 3:57 am
Default Re: Battery life/LCD brightness
Change your battery with new one. You may use mobile phone battery
Battery life Carpetartist Dead Players 1 27th Nov 2009 5:54 pm
How to change BATTERY for LONGER LIFE!!! d12nv Support and How To 7 1st May 2007 1:47 am
longer battery life marcolo86 General Discussion - Uxcell.com 3 30th Jan 2007 7:14 am
Battery Life?? tzcqdg General Discussion 3 29th Oct 2006 3:42 pm
Battery life pepe Support and How To 5 27th Jun 2006 3:39 pm
