Upgrade Firmware
Old 13th Mar 2007, 11:13 am
Default Upgrade Firmware
Not sure what player i have but the firmware is as follows :
MP3 PLAYER
LSD_9101_20
2006_10_21
9.0.50
Can i change the look of my player with a theme ?
ive tried extracting firmware but when i use s1res it says error
Can i download another firmware from here then edit that then update my player ?
i.e LSD_9112_20_2006-10-21_9.0.50
Could i edit that then update my player
please help b4 i brick my player lol
Old 13th Mar 2007, 2:51 pm
MasterMark .. simple answer "No"
9.0.50 isn't currently supported by the firmware extraction/Mod tool.
And please, don't even try to modify another version of firmware and upload that to your player. You will brick it.
Enjoy it as it is. A new version of the extraction and mod tools will hopefully be released soon
[hr:43af44b395]
Old 14th Mar 2007, 10:07 am
Default Re: Upgrade Firmware
Ok thanks alot ill wait for the new software then cheers
How to upgrade the firmware BLACKDRAGON Support and How To 1 14th Jan 2008 12:23 am
CANNOT UPGRADE FIRMWARE amishjha@gmail.com Support and How To 3 13th Oct 2006 11:15 pm
I want to upgrade my firmware.... hmx Support and How To 1 17th Jul 2006 7:17 am
firmware upgrade torkus General Discussion 3 13th Jul 2006 3:23 am
Firmware upgrade max2 Support and How To 4 8th Jul 2006 4:31 pm
