Need help with Rockchip mp4 player
Ok i have tons of questions and i really need help so plz help me as much as possible, also i'm not being picky or watever but it would really help and make me understand or read people's replies better if they answer it in a bullet point form like I did cuz a lot of posts i've read contained all the useful information in one paragraph and it's quite confusing or hard to read.....anyway plz help me as much as u guys can!!
1. I'm not sure wat type of MP4 player I have but I think it's a Rockchip player, the firmware version is 00.00.0004. I want to download the firmware update for it, can somebody plz give me the link to download the newest firmware version for it because i tried searching the site and only found the old ones or other irrelevant posts.....also can somebody post the firmware update tool and all the other essential programs/tools related to firmware that I need in order to update my MP4 player because my CD didn't come with the installers and tools etc... 2. How do I put games on my MP4? Where can I download free MP4 games and wat type of format are the games? Is there a program that can convert mobile phone games (.jar files) to MP4 games? 3. Where can I download ebooks or novels in texts so i can read it on my MP4? 4. Where can I download themes for my MP4? How do I change it? 5. I've heard from my friend that there's a new music format called 'vobis ogg', it's a highly compressed music format which is only 1/10 of the original music size and can still play the music files at high quality, i wanna use it so i can store more music files in my MP4, so does anyone know how to make your MP4 player play 'vorbis ogg' format because my MP4 can only play .mp3 music formats......is there a way to hack it change the system to make it do so or is there a program that u can install in ur MP4 player to make it play different formats? 6. Same with question 5 but this time is for videos, i wanna play wmv files on my MP4 and even though .avi files are good quality but it takes up too much space, i can compress the avi files but it's annoying since i have to do it for all my video files so i wanna use a format which is still a good quality but takes up less space than .avi files, is there a program that i can install on my MP4 so i can play .wmv or .mp4 files etc? that's all, plz help me, any reply is highly appreciated!! |
1. Firmware is not cross compatible so you would need an update from the manufacturer for your specific player. Updating with just any other firmware will most likely brick your player. Updating will not add any new features etc so you are best to leave it as is.
2. You can not add games they are encoded into the firmware. 3. Try Project Gutenburg for ebooks: http://promo.net/pg/ 4. You would need to try a .ogg file on your player if it is not recognised by your player then your player does not support the format. No way of adding support. 5. .wmv video format is not supported. |
| All times are GMT -7. The time now is 1:11 pm. |
