Problem with S1 Mp3 Player
Old 23rd Mar 2007, 12:53 pm
Default Problem with S1 Mp3 Player
Hi, I have bought one of those mp4 players from Hong Kong:
Productor: Wilson Co.Ltd.
Device Name: S1 Mp3 Player
Version: 9.0.50
The problem I'm having is, in one word, I cannot see some folders in the mp4 player, once I had copied it from my win XP.
Going in depth, I run fix disk on the drive, and see that the FAT32 is somehow corrupted, but anyway if I connect the device into my PC I can see the full content, even play the files (mp3) in the folders im not able to see in the player.
I tried formating the mp4 player from win xp, and also fixing the FAT32 drive several times, with no luck. I think that this happen the first time I transfer from my machine, that the device got disconnected from the usb cable, from that on, Im running with this FAT32 corruption issue.
Does this happen to anyone? Is there any way to fix it?
Thanks in advance!!
Sebas.
Old 23rd Mar 2007, 12:57 pm
Did you try the memory hack removal allready? Maybe the memory is hacked.
Old 23rd Mar 2007, 1:32 pm
Default Re: Problem with S1 Mp3 Player
No, where can I find that trick?
Old 23rd Mar 2007, 3:03 pm
Here is the link:
How to remove remove memory hack
problem with my mp4 player. lordik Support and How To 1 6th Oct 2006 3:26 am
I have a very big problem! MP4 4G Player Csaba Dead Players 1 6th Sep 2006 2:49 am
my mp4 player 2gb problem BONESZ Mods and Themes 2 8th Aug 2006 4:40 am
My mp3 player problem Jeans Support and How To 1 7th May 2006 9:15 pm
