Help needed syncing to my Chi-pod using WMP
Old 29th Mar 2007, 4:46 am
Default Help needed syncing to my Chi-pod using WMP
I have a 2GB nano-clone on to which I have transferred loads of music files using Windows Media Player 11. Trouble is using the "shuffle to device" function, it has created separate folders for each artiste and seperate sub-folders within those folders for each album. This makes it a right pain to browse given the limited browsing powers of the chi-pod. The chi-pod also slows right down when I try to toggle up and down the hierarchy making it a nightmare to change artiste folders.
Is there anything I can do to to make the tracks sync to the device as individual tracks without any sub-folders? I'm pretty sure I unchecked the "create folder hierarchy" option in "device settings" but it had no effect. Musicmatch Jukebox seems to be able to handle this without too much bother but I prefer to use WMP.
Thanks in advance.
Old 31st Mar 2007, 2:44 am
booster cogburn , the best solution to your problem would be to just use the drag and drop or copy and paste method. Just treat your player's removable drive as a normal USB thumbdrive.
This offers you full and better control on the folder structure.
Old 31st Mar 2007, 5:29 am
booster cogburn - I know exactly how you feel. Actually, there is a way to sync individual files. Just follow these steps:
1. Connect your player to your computer
2. Open windows media player
3. Click on the arrow underneath the sync tab and find the drive where your player is located.
4. Hold the mouse over that, and the arrow will show you a number of options. At the bottom, of the list, click on 'Advanced Options.'
5. The box called 'Create folder hierarchy on device' is probably checked. Uncheck it, click 'Apply,' and return to the synching process. It should now create individual files without folders.
Old 2nd Apr 2007, 1:50 am
Thanks very much for your answers lattesurf and princessanne1026. Both methods work perfectly well.
Help needed adribarse Dead Players 2 9th Jan 2010 3:19 am
ok help needed jaha017 Dead Players 0 13th Oct 2007 3:06 am
Help Needed Pls sarbe Dead Players 0 20th Jan 2007 8:34 am
Mp4 Help needed :( nanocopyuser Dead Players 12 16th Jan 2007 1:22 pm
help needed badboy Support and How To 20 11th Jun 2006 12:53 pm
