Help charging Future Muzro X3 player
Old 3rd Apr 2007, 7:41 pm
bax bax is offline
Default Help charging Future Muzro X3 player
when i connect my player to my PC it seems not charging the battery, even though i plug it in for 8 hours. one thing i noticed is that the connection is on and off. Since it is not charging, i can't turn on my player. anyone knows how to fix Muzro?
thanks!
Old 14th Apr 2007, 4:27 am
Default muzro x3 not charging
Hi. I have the same problem with you. My sister bought me muzro x3 and it doesnt charge on my pc? What did you do? is it ok now?
Old 14th Apr 2007, 8:23 am
bax & ajea , try the following:
1. Ensure the On/Off switch is at the ON position.
2. Use another USB cable, it could be a cable problem.
3. Try using the Wall adaptor if it came with one, but take note of the charging and do not overcharge.
See if these solves the problems.
mp3/mp4 player not charging heartlessarchangel Support and How To 9 18th Aug 2007 6:33 am
mp4 player charging xeongx General Discussion 7 17th Nov 2006 6:30 pm
Charging Mp4 Player Enprinte Support and How To 1 14th Jun 2006 2:42 am
To future mp4 player owner ROLLEYFLEX General Discussion 3 12th Jun 2006 2:03 pm
player on or off charging kaz Support and How To 5 29th May 2006 4:43 am
