Help - MP4 4GB Player
Old 4th Apr 2007, 9:09 pm
Default Help - MP4 4GB Player
Hey everyone!
Recently i bought a MP4 player of Ebay
When i got it i was just getting to know it just playing around playing the Default Songs and videos.. The day after i turned it on a Hour Glass Wont go away i dont know what this hour glass is doing but yeah its pissing me off.
Its Small and black and supposbly 4GB
I have the driver disk and when i go to install the driver this message comes up
I really love the look and weight of it
Please i ask please sombody to reply and help me out and get this hour glass go away and start play music
Thankyou
Sorry mods if this is in the wrong section!!'
Cheers
[align=justify:7f2f8ea35e]Click the image to open in full size.[/align:7f2f8ea35e]
Old 5th Apr 2007, 5:47 pm
no body?
Old 5th Apr 2007, 6:22 pm
Hi Marcello, I know how impatient you are and probably frustrated by not getting replies. Im sorry I couldnt help you with this problem but why dont you try other ideas like formatting or something like that. Im guessing other will have more detailed explanation on fixing your problem so wait around a day or 2.
Old 5th Apr 2007, 7:17 pm
Marcello , try formatting your player first. The guide is here http://www.mympxplayer.org/how-to-re...ck-vt2400.html
You should not need to install any drivers on your computer, as the player functions as a normal USB thumbdrive. So just plugging it in will detect the player. The driver is for Win98 which does not contain the required driver information.
Do you still remember your previous working firmware version number?
Old 5th Apr 2007, 10:02 pm
Thanks for the reply
Umm what the hell is a firmware version number?
sorry i guess im a noob at this
Cheers!
Old 5th Apr 2007, 10:19 pm
Alright more problems
When i put the usb into the computer the pc makes that noise "DO;DO" something like that but cant not see the removable disk.
Old 5th Apr 2007, 11:39 pm
Marcello , install MP3 Utilities, it should be in the CD that came with the player. Else, you can download it from the Downloads >> Tools section.
Next, start MP3 Utilities Disk Tools, see if it detects your player. If so, follow the steps here to format the player http://www.mympxplayer.org/how-to-re...ck-vt2400.html
If it does not detect your player, likely there would be a firmware problem.
The easiest solution would be to contact your seller for an exchange.
Old 6th Apr 2007, 3:08 am
If its a Firmware problem i guess im stuffed the guy who sold it to me is of ebay
but thanks for your help.. i guess i bought a dud
