-   -   AMV Converter Problem (http://mympx.org/forum/support-how/37583-amv-converter-problem.html)
grimlockwheelie 8th Apr 2007 10:11 am
HAVING AN ISSUE CONVERTING.....
When Running my AMV converter i'm having an issue. Whenever i run it i get a disk full error. This doesn't make alot of sense. I mean my hard drive has about 80gb free, my player is empty (a real 2gb player) (had a hacked one, but this one is really 2gb after format) Oh by the way my player is a 1.8 inch nano like player. (the second generation style (with the rounded case, not the split in two case). Well when i put a movie on there like transformers the movie, it works fine. (i changed the movie from my dvd to avi (using clonedvd mobile) and then changed it to amv with the amv converter. It worked wonderfully. When i went to do Empire strikes back it gets to anywhere from 65- 74% in the process and then tells me "disk full" with a little error message. I'm confused by this. Please help. (this is just when converting it from the avi to amv, not even when putting it on the player)
Thank you for any assistance you may have.
thanks as always, Timothy Radder
For the record, i love these little players, they're reliable, once you set them up anyway, and they are a great deal.
Also, Uxcell, great sight, ordered some accesories from there the other day.
