Help to fix my mp4 1gb 1.8"
Old 10th Apr 2007, 10:41 pm
Default Help to fix my mp4 1gb 1.8"
HI:
I hope someone can help me, i failed to change my mp4 firmware, and now the only thing that shows is a white screen and nothing works.
Im trying to fix it but any of the firmware i try to load is working
This is the information i have:
MP4 1GB 1.8" Screen
The firmware was:
-S1 MP3 Player made by Wilson Co. Ltd. Version 9.0.50
The chips are:
Samsung 649
K9L8G08U0M
PCB0
ATU2093H
I hope this information help you to tell me which firmware i need to install, because i tried a lot and some tell me success in the instalation with the MP3 Player Upgrade Tool but its still not working, only the white screen.
Old 11th Apr 2007, 5:58 am
luistkd , you'll need to try all the v9.0.xx series firmwares here http://www.mympxplayer.org/actions-9...mare-dc37.html
If these do not work, then there is nothing much you can do. As your original firmware was 9.0.50, it is currently not supported by the firmware extractor, so others with a working v9.0.50 are unable to extract theirs to upload to the forum.
Need "private key" and "devcert template" adminn Support and How To 1 31st May 2010 5:07 am
"Blown-z" now trading as "excesories" tadad1 Bad sellers/Blacklist 2 15th Feb 2007 5:09 pm
"Invalid upgrade firmware file" & "Flash AmitS Dead Players 1 26th Jan 2007 8:09 am
[solved] USB 2.0 "Full" and "Hi" speed i Zepheris Miscellaneous 4 12th May 2006 11:18 am
