Which battery terminal is positve?
Old 13th Apr 2007, 2:35 am
Default Which battery terminal is positve?
Hi I have this player
http://img301.imageshack.us/img301/6...c003472jr1.jpg
I just got a new battery. But now I cut off the wires of old battery without making any notes. I don't know which terminals are positive and negative. Can some body tell me which one is positive? The processor is ATJ2093H.
Regards
Old 13th Apr 2007, 2:48 am
loneranger , see if there is any markings on the two terminals.
But likely there won't be any. However, look for this small diode that is connected to either one of the terminals. One terminal would have it, the other without.
The terminal with the extra diode would be the +ve terminal.
Old 13th Apr 2007, 3:10 am
I don't see any diode. There is this wire going under the screen.
Old 13th Apr 2007, 10:02 am
loneranger , it's difficult telling which terminal is which. If you could, take a few closer & clearer pictures.
Old 17th Apr 2007, 5:52 am
Default Re: Which battery terminal is positve?
Thanks for your reply. Hope this helps.
http://img237.imageshack.us/img237/9...0091resaj3.jpg
http://img248.imageshack.us/img248/1...0076resll5.jpg
http://img237.imageshack.us/img237/8...0077resqn6.jpg
Regards
Old 17th Apr 2007, 6:10 am
loneranger , the 2nd picture, where you have a circle in it. I see abit of red stuff on the green circuit board, did the red thing come from the battery wire?
If so, that pin would be the +ve terminal, and the other -ve.
Old 17th Apr 2007, 7:48 am
There is a little red but I don't know if thats from the wire sheath. Its really hard to see.
Here is whole image of the player.
http://img120.imageshack.us/img120/7...098res1kl0.jpg
Is there any one else with the same player can look up and tell me the orientation of the wires terminal?
Old 17th Apr 2007, 9:25 am
loneranger , for me, i would just connect the 2 terminals, and flick the switch on. If it turns on, then you've got the terminals right.
If it does not turn on, then immediately flick the switch back off. Change the polarity of the terminals and you'll be done.
The battery with reversed polarity would hardly or even damage the player, as the voltage is very low. So i won't worry about it damaging the player should the terminals be wrong. Just don't charge the player with the wrong terminals and the player would be fine.
need new battery moneybankz Dead Players 0 20th May 2008 1:07 pm
ME2 Mp3 Mp4 Battery gloriaharvey Support and How To 4 6th Nov 2007 11:13 am
Take out battery KingGinola Support and How To 7 17th Feb 2007 9:27 am
battery katana General Discussion 5 24th Dec 2006 5:07 am
Battery Sua General Discussion 8 29th Nov 2006 7:21 pm
