problem with my mp4 player
Old 27th Apr 2007, 8:25 am
Default problem with my mp4 player
hi. anyone can help..
i hav a problem w/ my mp4, when i play an audio file, it restart(shut down and turn on again).. but thers nothing wrong when i play a video or use the FM radio..it plays normally.. so i think that the problems are my mp3 files so i deleted it and upload another mp3s on it but same problems occurs..
what seems to be the problem?
i also think to upgrade the firmware but im having a hardtime searching for the firmware of my mp4..
core: ACT9x-0.49
date: 2006-10-20
FW: SRX-1.5c-006
date: 2006-11-10
plss help.. tnx!
Old 27th Apr 2007, 8:56 am
arvin9783, You could try formating the player. The other thing that may be causing the problem is a hacked memory chip, you can check this by connecting your player and running the Disk Tool which is part of MP3 Player Utilities which should be on your mini CD or there are several versions in the Downloads\Tools section.
When you run the disk tool you will see 2 tabs one for Format and one for Partition. Have a look at both tabs and check the memory capacity they should read the same. If the format tab reads larger than the Partition tab then the memory may be hacked.
Old 28th Apr 2007, 12:04 am
Default Re: problem with my mp4 player
oh well.. thank u vry much sir.. ur right, sims that the memory may be hacked.. ive already done the "How To: Removing Memory Hack" in http://mympxplayer.org/how-to-removi...ck-vt2400.html. and it works..
but.. y is it that when i play music continuesly, my player gets hotter and hotter? (sorry, cant think for appropriate words :? )
im afraid it will turn to over heat :cry:
Old 28th Apr 2007, 12:20 am
arvin9783 , are you holding onto the player while listening? Your body heat might be transferring to the player itself.
Or else, is your player charging at the same time? It is normal for a player to get warm whilst charging.
If not, it could likely be a battery problem. If it's using a removable battery, try changing it. Else, you might want to contact your seller for an exchange, as it should not get hot just by playing music on itself.
problem with my mp4 player. lordik Support and How To 1 6th Oct 2006 3:26 am
I have a very big problem! MP4 4G Player Csaba Dead Players 1 6th Sep 2006 2:49 am
my mp4 player 2gb problem BONESZ Mods and Themes 2 8th Aug 2006 4:40 am
My mp3 player problem Jeans Support and How To 1 7th May 2006 9:15 pm
