-   -   firmware and flash errors (http://mympx.org/forum/support-how/37914-firmware-flash-errors.html)
Da_fixer 4th May 2007 2:05 pm
Hi
I want to mod my ipod 1gen clone Firmware (fw 3.5.37) with mypod theme but how can i resize the pic's to fit in my fw?
i can only mod 128x128 pic's bootscreen,change and menu screen.
not the batt,EQ.
and the Mp3 upgrading tool don't work on ms vista is ther a another flash
tool can flash onder vista?
lattesurf 5th May 2007 5:17 am
Da_fixer , you'll need some image editting software, like Photoshop or even MS Paint. You should be able to rotate/resize the images according to your firmware.
The MP3 Utilties was programmed for Win95,98,ME,XP & 2000. You might not be able to get it to work properly on Vista as it was recently released. Try to flash it on an XP or 2000 computer.
Da_fixer 12th May 2007 2:18 am
ok i wil try it thanks for the tips 8)
also i wil try it on xp pc, i'm installin xp on my laptop right now :D
