[solved] Problem with AMV Convertor 4.09
Old 16th May 2007, 3:10 pm
Default [solved] Problem with AMV Convertor 4.09
Hi I have just purchased a mp4 player that only supports amv format video and I got the 4.09 version of the convertor but when I try and convert a TV Show about 350mb in AVI format when I click convert it says error and 1 Failed. Can anyone please help me with this problem.
Old 16th May 2007, 6:23 pm
tom164, Install K-Lite Full codec pack on your PC and see if tht helps.
http://www.free-codecs.com/download_...hp?d=3406&s=95
Old 16th May 2007, 6:36 pm
Default Re: Problem with AMV Convertor 4.09
Cheers tadad1 its all working fine know
Old 21st May 2007, 5:02 am
i have the same problem.. i installed K-Lite Full codec pack, but it still doesnt work
ChiPod nano (2Gen) - 2000 Songs, impossibly real-looking!
...i love my iPod nano Clone 4GB!!
^ NEW SITE TITLE LOGO!! ^
Whole DVD to avi convertor for my player hoekone Video related 4 9th Jul 2008 4:49 pm
AMV convertor 4.09 worked once vx255 Video related 6 3rd May 2007 1:37 am
[solved] Problem with AMV convertor - can't convert files Tina Video related 5 1st Jul 2006 9:09 am
[solved] Convertor - cannot use 'settings' jvb1982 Video related 2 1st May 2006 12:49 pm
hi i am looking for amv convertor IRFAN Video related 1 14th Apr 2006 12:35 pm
