How to build a portable charger for your MPx Player
Old 22nd Apr 2008, 10:19 pm
I just got a 1500mah rechargeable battery. Has solar charger on it too. About 9.5 x 4 x 1.25 cm. Just a bit bigger than a Nano. They build it in basically the same case as a Chipod.
Many Chipods have 270mah batteries. With this add-on, I would expect to get over 5 times the amount of run time. Since it has a solar cell on it, it could run a heck of a lot longer. Has cool LED flashlight. Uses the same AC adapter and usb cable as chipods do.
I got it on ebay for $13 including shipping http://search.ebay.com/search/search...+Solar+Charger
It charges my Razr phone and my thumb drive mp3 player.
If you make a battery pack from 4 rechargeable batteries, you probably won't need a regulator. NiCad and NmHd are about 1.2V each. 4 x 1.2V = 4.8V Close enough to 5V
A regulator wastes a lot of battery power as heat.
will this mp3 charger work with my player? kermit12 Support and How To 0 13th Oct 2007 8:53 pm
Help with my portable mp4-mp3 game player Desperado Support and How To 1 26th Sep 2007 7:26 pm
Install a Portable OS on a MP4 Player lesmo_sft Support and How To 0 17th Jul 2007 10:50 pm
Build your own MP3 player womblebongo General Discussion 1 31st May 2007 6:43 am
how can i build my own firmware?? ok1 General Discussion 6 26th Sep 2006 5:43 am
