How to build a portable charger for your MPx Player
Old 29th May 2007, 3:08 pm
Default How to build a portable charger for your MPx Player
Alright so I never really thought of the practicality of a portable charger until today. So I built one in the last half hour. It works with my MPx. Anyways, according to some threads, I found people getting many times more hours out of the external charger than the battery. So let's get at it.
First, a parts list. Now in this one I will be using the 4 AA battery pack, though it is just as easy to make it with the 4 AAA pack or even a 9V battery.
Parts needed:
Some kind of portable power source:
4 AAA Battery pack:
http://www.radioshack.com/product/in...entPage=family
OR 4 AA Battery pack:
OR 9V Battery clip:
7805 Power regulator:
http://www.radioshack.com/product/in...entPage=search
USB End
I usually get these from tearing apart free usb hubs I pick up at conventions, cause they're all usb 1.1
Some wire
Soldering skills
Pin layout for 7805:
Pins for usb:
So if we're working from the pics, then the wiring is straight forward.
Instructions:
1) Connect the red wire from your battery pack to the input pin on the 7805.
2) Connect the black wire from your battery pack to the Common on the 7805.
3) Connect the output pin of the 7805 to Pin 1 on the USB end.
4) Connect the Common pin of the 7805 to Pin 4 on the USB end.
And that's it!
Post pics if you made a creative case!
*EDIT*
Although mine charged fine, some of yours may require it to be on that "CONNECTED" screen to actually see it charging. In order to see this, connect pin 4 on the USB end to pins 2 and 3 on the USB end.
Old 29th May 2007, 7:35 pm
Default Re: How to build a portable charger for your MPx Player
Or if you prefer it to look really professional check out this sweet unit
http://www.houseofdap.com/index.php?...d&productId=38
Dave
Old 30th May 2007, 1:42 am
or somthing much eaiser to use check out this one
http://www.dealextreme.com/details.dx/sku.3060
rechargeable 2500 mah , it will recharge your m6 4 times fully on one charge of it
Old 30th May 2007, 2:16 am
Maybe I'll find how to build a better charge pump and hook it to a standard phone battery... hmm...
Old 30th May 2007, 2:26 am
create somthing so it can recahrge itself and give out power from the same USB port > use a am > am usb for charging. with a simple 2 way switch
Old 30th May 2007, 2:43 am
Yeah I see where you're getting at. Right now I'm just using disposable batteries, so it's kinda futile. However, with a rechargeable option it will be more feasible.
I wanted to do this quick and nasty fix today, cause I work all the time. Gonna draw up some schematics on how to make it more awsome. This was a dirty job version.
Nice thing about mine though is that I can power up multiple devices if I wish, just attaching more ports in parallel. Pointless, but hey it's something!
Does anybody know the maximum mA you should blast into these guys? I know USB peaks out at I believe 500mA. I don't want too many amps going into my little pride and joy haha.
Old 30th May 2007, 3:28 am
Thanks for sharing this with us all XBrav!
Great work on the device and thanks for passing on the guide to everyone else.
Old 30th May 2007, 4:02 am
hi peeps
thought i would throw my bit in
bought following of uxcell
http://www.uxcell.com/uxcell/retail/...07011100ux0004
and
http://www.uxcell.com/uxcell/retail/...06112400ux0003
to charge my and my kids players when out and about and they are in bed etc
BUT DO NOT WORK
will work on rockchip players thought but not on ANY actions based players that i own. i do not know what they do with ntheir usb ports on the actions players but they are wierd. none of the above from uxcell work on my players but will on rocks. just a note to those who listed alternatives in this post - just beware thay most probably will not work!!
this is my experience anyway - currently trying to relate this to uxcell with little progress - language barriers etc
cheers
Old 30th May 2007, 12:15 pm
Originally Posted by makd511";p=&quot View Post
hi peeps
and
BUT DO NOT WORK
cheers
I believe it doesn't work because some require PC confirmation before charging (sorry for terminology). Some players start charging as soon as they see +5V on the VCC. Others require a PC link, which is a pain to emulate.
Someday I'll figure out a way to do it easily, but for now it might be kinda hard.
*Update*
So by shorting the D+ and D- on the usb, I got even better results. So I'll add it into the instructions.
Old 31st May 2007, 12:40 pm
Here`s much prettier one with same instructions: http://www.instructables.com/id/E7NY7843WIEQHOAXQ7/
I will try this, when I get the right parts. :wink:
will this mp3 charger work with my player? kermit12 Support and How To 0 13th Oct 2007 8:53 pm
Help with my portable mp4-mp3 game player Desperado Support and How To 1 26th Sep 2007 7:26 pm
Install a Portable OS on a MP4 Player lesmo_sft Support and How To 0 17th Jul 2007 10:50 pm
Build your own MP3 player womblebongo General Discussion 1 31st May 2007 6:43 am
how can i build my own firmware?? ok1 General Discussion 6 26th Sep 2006 5:43 am
